Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  David Gutierrez
  Thief River Falls, MN - USA
Aircraft:
  RV-7/7A
Total Build Hours:
  155
Web Site:
  http://www.mykitlog.com/RVGman/
Date:  01-21-2013
Number of Hours:  3.28
Short Description:  Left elevator
Today, I assembled the trim motor to the accessing plate. I did this by mounting the brackets that hold the motor to the access plate by back riveting those brackets onto the plate with three 3-3.5 flush rivets. Prior to that I dimpled the plate appropriately.
Caleb and I the bent the flanges on the elevator skins as was described in the manaul for where the trim tab will go. This was done over wooden blocks that were cut on the mitter saw to the right wedge angle. We then stuck double sided tape to the blocks which keeps it from moving while we pound on it. We then them with the but of a hammer did the finish work with the rivet gun and the flush rivet set.
Once we got that done then we riveted together the E-704 and E-705 followed by riveting on the spar reinforcement and nut plates.
We then called it a night.
 Recent Builder Activity
Builder Project Date Hours
Jim Novak
RV-8
06-13
3678
Brad Kunkel
Zodiac CH 601 XLB
06-11
1116
Charles Wright
RV-8
06-09
135
JAMES TRAYNOR
VELOCITY- XLRG
06-05
2643
Keith Borgstrom
Sonex
06-05
527
Jack Clark
RV-14A
06-04
1464
Neil Rosoff
EX-3
06-01
1167
Michael Freiherr von Maltzahn
RV-12is
05-29
513
Darrel Watson
H-5
05-25
930
Mark Jackson
RV-8
05-17
1674
Stuart Hutchison
F1 Rocket Sport Wing VH-FLY
05-16
4236
Mark Johnson
RV-10
05-09
753
Peter McBain
RV-9A
05-08
2326
Robert Lussow
RV-15
04-13
Robert Lussow
RV-10
04-13
2834
Robert Lussow
RV-15
04-12
Brian Robinson
Xenos
03-20
Bob Grantham
SeaRey LSX - "Spirit of Mackenzie"
03-11
2234
Joe Loxterkamp
https://eaabuilderslog.org/
02-12
James Chadwick
RV-7
02-01
1013
Mark Spedding
COZY MK IV
01-14
3925
Randy Doughty
CH750 Cruzer
01-10
1001
Stephen Satava
RV-7
12-30
2967
Chuck Bennett
Sonex-B Tri-Gear
12-28
1399
Andrey Piskarev
Highlander
12-27
4497
Richard Tice
RV 7
12-09
987
Doug Volkmer
RV-7
11-24
1250
Stephen Eastham
CH-601 HDS
11-17
564
Robert Chopin
RV-8
11-15
868
Mark Weitkamp
CX4
11-09
3047
Projects Uploaded: 1564
Logs Uploaded: 288586
Copyright © 2001-2026 Matronics. All Rights Reserved. Privacy Policy.
