Brief Description: fit cowlng, trim seals, mark for cowl adjustment
Went to put top cowl on today after trimming baffle seals to lowerr cowl for fit. Didn't fit well. Seems like top is too long... did cowl fitting with engine and prop on 2 years ago. Only thing I can think of is the replacement engine mount must be a tad longer. Will need to trim cowling to fit. Marked top cowl aft and nose for trimming.
Sanded R wing tip gap that I super-filled last week Sanded foam mess off of both wing tips. Sanded both inboard flaps areas. Left is good to go...right side had a few pinholes, but the contour is good
