Brief Description: pull wires for recognition wing tip lights
Ran R-B-W 18 ga wire from both tips into fuselage through leading edge conduit. Also ran a WH 20 ga wire. Pulled through with a fish tape without too much trouble.This is to wire the Aeroled Sunray Plus recognition/landing lighst per wiring diagram. Had to pull seats and side panels out to do this, however. Getting pretty good at it!
Wires are run, but I only connected the R and B 20 gauge as the VP can control the wig wag. That will eliminate several connections. Used meter to find the unused "cooling fan" wires running to aft area. Found them and spiced the wing wires into the R-B using butt splices.
Did not wire molex connectors yet...waiting to see what comes with the lights. Ordered from ACS yesterday
