Brief Description: work on running static & pitot lines
ran static line most of the way - left side; connected all fittings on instruments; rough run pitot line on right side. Need more 1/4" nynaflow tubing. Had 30' and need about 20 feet more. Not sure how Lancair figured that!
Used Dupont 592 thread sealant on all connections.
Need to find out if "encoder" (G330) takes a static line input. No fittings on transponder, but Lancair manual calls for a static line to the "encoder"
