Pitot tube wold not fit in flange installed in wing. Used a round perma-grit tool to grind out some off the inside. A couple passes and it fits.
Next... the 4 screw holes did not line up. Two were off quite a bit. Fooled with that for quite a while. Drilled one additional hole and elongated another enough to fit. Should work OK. Probably mis-drilled at Lancair as this flange was pre-installed in the wing skin for builder's assist.
