2' step ladder and swivel chair to support if alone lower cowl aft - shift as much aft as possible and add 1/8" - 1/4" shim to spinner area, particularly the lower cowl; add skybolts to top of lower cowl - aft (midway point)
Front top cowl - both sides
top cowl - left aft corner
4 nose inlet skybolts - both sides
set 2/3 top aft edge left side
Then set top - aft - right corner
2 skybolts to bottom cowl to bottom fuselage
*** will need to modfy procedure when nose strut fariing is added***
every other skybolt across top cowling - aft end; then fill in
every other top cowl left side; -10 stud to # 4 up on aft edge of top cowl; then fill in
every other top cowl right side; then fill in
2 8-32 CS machine screws to outisde of each nose inlet
