Brief Description: cowling back on; check gap; record install procedu
Tried to load AFS W&B file that I edited on Notepad. NOGO. Will try with WORD and save as a AFD file.
Used shims at bottom cowl to hold gap while I put cowling back on. Documented order and procedure. Will post here later. Still may need to add washers to push engine out 1/8". Will run and see what it looks like.
