Brief Description: work on adding COM 2 to belly & misc.
need to solder ground wire from antenna to copper ground plane need to get some SS c/s screws to mount antenna to plate need to add 1 BID to cover copper foil ?? run wire from ground plane to system ground??? Prob should do.
