Brief Description: AFS W&B and Maint. schedule files
Used Notepad to edit file. Must save as a ".AFD" file, not as a default text file. That means adding ".AFD" to the file name and changing the type to "all files" as opposed to the default type of ".txt"
Edited W&B stations; changed min. fuel to 17 gallons; that drives a CG calc. at that configuration.
On the MAINT.AFD file I needed to reset system clock to get right dates using the update feature. It did not read the dates as edited in the AFD file as suggested by the manual. Kinda frustratingbut in the end...DONE.
