Brief Description: AFS & VP alarms; reset guage ranges for Fuel PSI a
Backed up files to SD card and then to notebook.
Also worked on left fuel tank reading correct digital gallons, but the bars is empty on the R EFIS only. Tank 1 shows a capacity of like 47000000... s/b 52. I think that is causing the problem. The digital read out is correct however. Tried restoring old backup file from 1/28/12 as it worked fine until a week or two ago. Can not change this find directly. NOGO. Took pics that did not turn out very clear. Will research with AFS.
