Brief Description: tighten all panel brackets; ground VP control unit
tighten all panel brackets; ground VP control unit. Continue to route power and ground wires behind panel... this is endless.
Most wires are run to about where they need to be. Need to clean up a bit more and then start terminating the wires to the respective connectors....mostly the big round P-1 connector.
