Brief Description: run static line and COM 2 antenna cable
ran static line up with left side cable run. Added a few add'l smaller adels to hold 1/4" static line and RG400 for COM 2. installed all pitot and static connectors.
Need to find out whether there should be a static connection to encoder as shown in Lancair manual. I pulled G330 transponder and see no connection for a static line. Will check with Jeff at Aerotronics.
