used washer set up to level magnetometer...1st to fuselage level and then to EFIS1 in panel. Added brass washers as needed. Torqued down all nuts (brass) , added torque seal; checked that cable is tight.
Digital level would not fit back with magnetometer...used small torpedo level. Looks good.
