forgot camera this week so got just a few pics with cell phone.
figure out and install ground ring on oil and fuel pressure sensors
tag all engine sensors wires by referencing AFS wiring diagram
Install oil temp sensor with Loctite 592; safety wire
RPM sensor....fond one installed on right mag...probably installed by Barrett with engine work. Decided to use it and wire AFS leads to it. New AFS sensor in parts box
Install Fuel Flow red cube sensor. Might need to put fire sleeve over it
Run (rough) all engine sensor wires
Install adel clams and wire ties on all main wire bundles
