N144GP Lancair Super ES
Lancair Super ES
Vert Stab - Rudder
3-22-2009
enlarge inside rudder holes; grind 6 BID on bellcr
Had to grind a small portion of the 6 BID on the rudder bellcrank platform so that the stop bracket would sit flush.
Enlarged inside rudder push rod holes to allow for adequate clearance (mostly for the rivits holding the rod ends)
grind 6 BID
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
