Brief Description: check VS angle, enlarge rudder holes
check angle of TE of VS. Old manual says s/b 65 degrees (page 15-6); measured at 65.6 degress and seats well on fuselage and HS. Should be OK. Research cutting off thn skins at botton of VS below fuselage joggle. Concluded that they can be cut off. Cut off both sides. Enlarge holes for rudder push tubes in rudder spar. Rework bellcrank hardware after drilling out floxed in main bolt, last week Pull rest of rudder cable and parts, research how they will ultimately connect
