Brief Description: AN3-6 bolts and castle nuts to crossover tube
put in correct length of drilled AN3 bolts to front rudder cable connections;
Check all bolts/nuts on all brake pedal and cylinder connections for proper fasteners, castle nuts and cotter pins; no washers on brake connections per new ES manual (old does show some on nut side of connection)
