Brief Description: cut about .25" off of oil stud to accept Airwolf a
Used Dremel with a metal cut off wheel...dressed a bit with file. Put paper towel in oil adapter openings to catch metal filings; pulled paper towel and used magnet to pick up any stray filings.
Threaded old filter on first....worked well. Then tried threading aluminum Airwolf adpater....all OK. Minor dressing with file...didn't want to bugger it up any so didn't push things. This adapter will not be removed from engine so pretty didn't matter.
Need some Dow DC-4 silicone grease to mount adapter with o-ring......will order from ACS
cut off with dremel while on engine
before dressing with file
filter spins on flush now - will mount adapter next week
