Drain plug is in a bear of a place. Decided to put in a quick drain as I will need to change the oil every 4 months or so. Will still be a challenge, but should be able to get a hose on through the front nose strut opening, and turn the quick drain fitting. Also installing an Airwolf remote oil filter. Expensive (about $500) but the stock filter is nearly impossible to get to and it is mounted with the oil opening DOWN!!! What a mess that would be on a recurring basis.
