Brief Description: continue hanging engine - reconnect things
Continue working on re-installing engine. Just an example of seemingly simple tasks that end up taking a long time. Had to pull the bolts holding the fuel spider so that the throttle bracket could be attached. Had to unbolt spider bracket, and two AL spacers, then reattach with throttle bracket on....s/b a couple minutes. Except I dropped the friggin spacer down into the baffles. Of course it was alum. so the magnet wouldn't work. Tried for over 1 hour to get it and was close...but it got away from me. Ended of taking 7 -5 washers and making my own spacers.
