Brief Description: fit cowling;layout holes for skybolts; drill & cle
19 across the top at 3.8" 4 on each side of lower cowl, 3.8" 2 underneath 10 on each side; 4.2" spacing on left side and 4.1" on right....spaced them to be visually even 2 on inside of each cowl inlet prob. need a regular nutpate on each outboard side of inlets (not enough room for the skybolt receptacle) Will also use these Skybolts for nose gear fairing....will need to order some more. Run about $10 per hole but very nice....floating receptacle and adjustable depth #30 hole for clecos...will open up to 15/32" with unibit for grommets and receptacles
