Brief Description: Trim right side of upper fuselage
Test fit upper fuselage to lower. Trim on right side as necessary. Minor trimming required.
Placed 2 inch tape on bottom fuselage aligned with bottom of joggle. Then set compass to 2 inches, and tracked bottom of tape with point, thereby marking the top 2 " up. Then trimmed top fuselage to this line. Just a small rise in the middle, maybe 1/8". Left side was lined up fine.
