General feeling from the Lancair groups is that the stock pressure on the door seal (20 PSI) is too high. Some have turned the adjustment screw 1 full turn CCW to lower. I started with 1/2 turn. Will test and adjust as necessary
Adjustment screw is on pressure switch, with pump, between the 2 spade terminals
