Brief Description: aileron servo rod - bent threaded portion
Discovered I bent one of the rod ends to the roll servo attached to the aileron tubes... probably in trying to adjust things. Straightened bent threaded portion and ran 10-32 fine die over it. Seems OK...may replace anyway.
The part number looks to be...Aurora M 14 - 3 300 or MM-3 300, probably the latter.
