Brief Description: continue set up of shop; build engine stand to tur
Ordered rest of tools needed and made a list of materials needed to finish up cutting and layout areas.
Sent an e-mail to beg a 37 degree flaring tool from some friends....about $90 at Spruce and will likely never use it again.
Used Jeffco epxoy pump from Ron Galbraith showed up while I was in Oregon. Cleaned up well...should be OK. Got it for half price ... $145. Will offer it up for sale when I am done to help another builder with a very special purpose tool.
Assembled engine stand that will be used to turn fuselage to aid in finsh work; reviewed firewall blueprint to devise way to mount fuse using engine mount holes to engine stand..I think it will work.
Tested new furnance as the propane tank was set, connected and filled while I was at Lancair the last 2 weeks. No ductwork yet, but furnace works well...probably don't need ductwork for downstairs only, but would probably work more evenly with it.
I will check with son Chris on his plans for getting it done.
