Purchased 2 sheets of fiberglas tub-board from Lowes; applied to workbench for lay up table and to cutting table; drilled holes in rafters for bolts to hang wings with rachet straps...4 straps for each wing; installed kitchen exhaust fan in window over what will be lay-up table; used a sheet of OSB cut to fit lower window opening Misc. sorting of tools, etc. Moved tractor and ATVs outside to clear 2nd garage bay Received used epoxy pump from Ron Galbraith...fits into epoxy heat box just fine (an old kitchen cabinet from York house) Spoke to Tony Partain Friday....he expects to pick up ES in Redmond 1/4/08 or 1/5....to AZ to drop a Legacy, then to Ohio and PA....estimates 1/14 or 1/15/08...we'll see. It has been hard to get any info from Tony.
