Brief Description: mount bolts. trim door flange, skybolt 4 nose gear
AN7-14A plus 1 washer to pilot side lower engine mount AN7-16A plus 2 wahsers to co-pilot side lower engine mount AN7-26A to middle with 1 washer; replace open end washer with solid washer
torqued all to 40#...add 4-5 # if torqued from bolt side
End result is the engine mount is shimmed out by the thickness of one -7 flat washer...should shift mount forward by ~1/8" and should eliminate spinner rub on lower cowling.
dropped one -7 nut under floorbaord; took a while and removing fuel tunnel cover to get it out.
Trailer prop by to KCXY...will get to Sensencih prop shop for an exam.
