Brief Description: replace static line; work on MG wheel pants covers
replaced nylon T fitting to backup AS indicator and section of line from ASI to backup altimeter. Had fooled with this before to fix a static leak.... finally just replaced fitting...the threads were all boogered up. Lengthened line to increase the radius of the bend a bit.
Pulled MG pant access panels to replace nut plates as screws were loose after last flight. Upon closer inspection it seems the screw condition/lengths may be at fault. Replaced screws as necessary. Will keep an eye on them.
Checked out brakes rotors and pads while I was in there. Some brake dust, but things looked good. The little "zit" on the top of the R wheel pant appears to be caused by the brake line fitting. May put a rubber pad there to prevent further damage, then fix outside cosmetically
