pressure tested fuel tanks both wings; RW had small leak...by sound it was isolated to bay #6 in the corner...too little Hysol squeeze out. Luckily the aileron bell crank access panel was right there....Added hysol and drew it in by vacuum., set helped along with 500W halogen light. Pressure tested OK. Left wing was OK after fooling around with the wrong fitting in the test kit for too long. All is good, as Adam would say.
Added 2 BID to leading edge of LW after applying micro to joggle.
leak in RW - bay #6 in corner; used shop vac to draw Hysol in from the offending corner
