N144GP Lancair Super ES
Lancair Super ES
Horizontal Stab
9-19-2010
add 2 BID to bottom HS to fuselage joint
add 2 BID to underside of HS to fuselage joint; used 1 1/4" PVC pipe to make fillet.
Had to grind down excess edge of HS cradle to accpet the 1 1/4" diameter fillet. Used cone shaped perma-grit bit.
with peel ply
1 1/4" fillet
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
