hang right aileron so I can work on aileron controls; Set aileron to neutral (aligned to wing chord) and clamped. Measured and cut outboard pushrod. As a side benefit, once the pushrod was installed, the aileron bellcrank in the wing could be set and fixed to neutral. This will aid in installing the long aileron pushtubes from the fuselage to the wing.
hung aileron without tightening bolts
align and clamp aileron to wing ... in neutral position
