installed 3 flap brackets on right wing in preparation for fiiting flap onto wing tomorrow. Very difficult as the access panels are very small for my big hands. Was able to use a right angle air drill which helped alot once the bolts were started. Torqued and applied torque seal.
outboard most access panel...very small; had to get hand in there to tighten 4 bolts
brackets attached
inboard most bracket; tommorrow will fit flap on to check fairing fit
