Need somemore fiddling with the flap pushrod. I think right is OK now...need to shorten left side by about .3-.4 inches. Then work on setting the travel.
The wing fairing junctions to the flaps suck. I did not have the flaps on when I did the fairing 3+ years ago. May fair in some foam and micro to ease the transition. Off by 1/4-3/16". Could be a future project
Also need to trim about 1/4" off flap where it meets each aileron and ease that line into the TE of the flap at the wing fairing. Had talked to Tim Ong about this a while back. Apparrently a common issue.
