N144GP Lancair Super ES
Lancair Super ES
Speed Brakes
8-6-2018
SB J1 control cable wiring
fast ons to brown and white... will go to upper and lower terminals of switch (correct DPST switch on its way from Stein)
need one add'l female faston for red 24+ power lead that goes to swich center terminal
soldered ground pig tail to green LED; butt spliced to other 2 ground leads (ship ground and ground wire to ALC)
soldered red pig tail to 24+ on green LED (white dot terminal); butt spliced to blue ALC lead; installed 24v green LED to panel
green, orange, yellow wires from ALC not used; taped up and kept for future spares
J1 cable form ALC through fuel tunnel
cable routed; terminating wires
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
