no pics metering out GNS530 to GTX 45R GPS posiiton source signal Open up connector P13, inspect pins 25 and 26; meter out wires from that connector to 530 and GTX. All good Verify G3X and G530 config settings... looks correct. Sent pics to Jason. He concurs
Next step is to put it all back together, roll outside and power up eveything looking for any error msg pop ups. Jason says if something isnt communicating a pop up msg box should occur.
f none, go fly it again and get a new ADSB performance report.
Tired, frustrated, and cold. Ready for this upgrade to be done.
Lesson to those still building... build with the thought in mind that you will some day need to undo everything you did. Access, service loops, wire routing, easy to use connectors, etc. You are NOT done when you build and install it.
