Brief Description: Batts (2014) A=27.3v, B (2012) =26.2 volts
Prob need to replace the B battery. 2012 and at 26.2 after full charge by itself. Will install new batteries after G3X upgrade is complete. Will move A to B and put new batts in A. Odyssey PC 680
Install 1A fuses on Alt 1 shunt per Garmin manual; both leads and shrink tubed each
not the prettiest, but it will work. Hard spot to work in
