Brief Description: Study P-8 wires CP stick; rewire pitot; zip ties
rewired pitot to manual and per T with Jason. Pitot heat HEATS. check. Re-attach various mounting tabs, redo zip ties; test that CHT, EGT and OAT temps are reasonable. All within 5 degress F. Reattach elevator tube to torque tube after redoing zips in tunnel detail pics of P8 on phone; will send to Jason...to get flaps to work on co-pilot stick. VP was a ground controlled input...now it is a 24+ input. Need to find right flap wire in P8 - 28 pin grouping Pull out the flap wire from that ground group on pin 28 and move to pin 17...power in
