Brief Description: Relocate dimmer; pilot side rails; route and conne
No pics... looks much like it did Saturday afternoon when I hung the panel.
Had to relocate dimmer module... moved to rails on pilot side.
Most plugs connected. Discovered that I ran the GMU 22 magnometer cable the wrong way. Ran it forward to aft, then had pinned it in the tail. Have two lesbian plugs up front now!
Unpinned both CPC connectors. Will pull cable out, reverse direction and then re-pin and reconnect the CPCs. The other option would replace male pins with female, and vice versa, but I didn't have the female pins. Pulling the cable out may be quicker/easier in the end anyway.
Decided to add braces to each side at top of panel to firm up. Started thinking/planning about that.
