Ran EGT, CHT and EIS wires to GEA 24 connectors Installed EGT and CHT probes. Need #6 small ring terminals to make final connection. They were NOT supplied and I don't have any that small. Will put togther a AS order.
Plan install of oil pressure, fuel pressure, MAP sensors. Much different than old AFS sensors. Need some AN fittings as well to make the connections
