Brief Description: install defroster; adels for wire run; ready for i
Panel is to ship this week, so I got things as ready as I could. Installed defroster to 3 clic bond studs using flat washers... should work. added loose adel clamps for wire runs. Will final size after all wires are run. These in pic will be flipped up to be on top. Tidied up wires a bit. ran wire for flap up/down sense switch. Located near POS12 under rear seat. Ran to where P5 connector is. Jason is running the flap sense circuit to P5, so will add the up/down wire to that connector as needed. (was needed with old AFS AOA... not sure about G3X) Was easy to run now. Was going to add rivnuts to VR #1 for ease of service. Already in with 1 nut plate and 1 floxed in stud. All good.
adels added to wire runs; in loose for now; tidied up a bit.
Nut and large flat washer for defroster install - 3 studs
