N144GP Lancair Super ES
Date:  8-11-2018
Number of Hours:  2.50
Brief Description:  SB install switch, test, finalize
Tested per Precise Flight instructions including retraction by pulling CB. They really snap back down at loss of power!
Re-installed the rest of the interior and seats
Still need to place provided placards for switch/light, CB and at each SB pocket. Forgot!
Trimmed drain tubes flush with bottom of each wing.
In troubleshooting and final testing, I determined that I tapped power for the speed brake 3A CB from a buss tied to the avionics master. So, avionics master switch needs to be ON for SBs to work
Made log book entry. 25.25 hours to install
switch up, light on, SBs up
L side up
L side up
R side... bad pic through window
