N144GP Lancair Super ES
Lancair Super ES
run engine and misc clean up
Number of items noted during longer run up:
VP is showing red "engine" and "OAT".. need to check out
AFS RPM bug seems high....verify setting; s/b at 1700 rpm
got alarms for oil temp, volts and fuel level...check AFS settings for proper values
Sec alt came on after start...not primary...verify/change; seems to be charging
ADI did not acquire GPS signal, but did power up; 530W acquired GPS
fuel pump came on after engine initially stalled...why? check set up
pitot heat came on....cover was melted a bit...OAT was 36/2...might have overrode everything
IAS was between 30 and 60...but realized cover was on pitot tube...check again with cover off of pitot...about 30+ at idle
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
