N144GP Lancair Super ES
Lancair Super ES
reinstall ELT and test
reassemble reworked head to new battery including O ring
power must be off...at top of hour moved main ELT switch to "arrmed"; got test cyle signal and one
beep
WITH POWER STILL OFF.... pressed test button on panel...got 1 second signal sweep and a single beep and a light flash. All good
left GPS cable unplugged for now...will plug in after test flight. Not sure if anything in there caused the issue with the ELT and/or the ADI.
**Manual suggets that power (master) must be off to test ELT** Will verify that.
ELT reinstalled
resecure all wires
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
