Brief Description: fit elev. and mark for initial trim
set clearance gap to 3/16" minimum per manual.... blue line. Then lowered elevator and remarked same 3/16" gap with a green sharpie. This second line is slightly outside of first blue line at spots (rear). Will trim to green line.
Will pull elevators off next week and trim on the work bench.
Will let final 30 degree aft trim cut go until rudder is re-mounted.
Needed Phil's help to hang elevators. Not too bad with 2 sets of hands.... near inpossible alone.
