N144GP Lancair Super ES
Date: 12-24-2014
Number of Hours: 6.00
Brief Description: cover interior panels
I ordered a roll of fabric for Oregon Aero when they did my seats years ago; to match the blue fabric inserts in my seats. Also ordered grey leather which I will use on the headliner.
Used Loctite spray adhesive, high tack, medium strength. Sprayed both surfaces to be mated. Foam and panel, as well as fabric to foam. Used 1/4" upholstery foam I sourced online.
Turned out pretty well. After cutting, and while pulling tight, this particular fabric wanted to shread a bit. Not a quality issue, just the nature of the fabric weave.
Still debating whether to apply the soundproofing to the inside surface of the panels. Weight versus sound reduction/heat.
Oh, BTW, plane is down at Airframes Inc, Brad Simmons, getting final professional bodywork and paint. Been there a month, with no expectation date and no firm price! Brad is a good guy with an excellent reputation. Does wonderful work.
Two of the pics are cloudy.... camera was outside in ny 18F car and it was 72 in the cabin.
foam on, ready to cut fabric to fit
foam cut out and applied to panel
back side, fabric glued down
