Brief Description: replaced RG58 coax in VS with RG400
While RG58 is probably Ok, there are folks that say to use RG400. VS is not closed yet, so it was easy to take out the RG58 I previously put in and replaced with RG400....not worth the chanace. This is COM1.
Need to re-calibrate my multi-layer stripping tool for the RG400....shield cut is OK, but insulator cut is not quite deep enough
