Brief Description: AFS setup; trim troubleshoot; pics of VP & AFS set
trim annuciators do not move when trim is moved. set up issue? VP or AFS? e-mailed Jeff at Aerontronics. He says trim never set up through VP, must do through AFS. I had this working. Pretty sure I did it through VP whether I should have or not. Now, no go.
If I dead-end with Jeff, again, I wil try Marc Ausman and Rob Hickman together.
I will try disabling settings in VP and doing through AFS. Need to check wiring diagram first
