Brief Description: re-do BNCs on RG400; install GPS TNC
In researching how to do the $44 AMP TNC connector for the G530 to GPS antenna, I realized that I neglected to mechanically crimp the center conductor on all the prior BNCs. Shit. I put the VOM on a couple runs and they seemed good, but it seemed prudent to re-do the ones under the panel while it was easy. I had left service loops so I had enough cable to re-do these. Will need to order some more male BNCs to finish the rest.
Did GS to splitter; COM2 to antenna lead; NAV antenna to splitter; VOR1 to splitter.
Still need to do splitter to VOR2; COM2 antenna end and transponder antenna end
