Brief Description: panel wiring and connections, continued...
add BNC to transponder; fabbed extra cable length....one male end and one female end; connect to Garmin 330 Route and connect P-5 connector...trim circuits E-mail Jeff at Aerotronics re CAT 5 ethernet connections to hub; no signs of power wire and connector. He says it is there. Will crwal up UNDER the panel next week and see if I can find it. Supposed to be off the fuse block...red and black pair...with connector. 3 pin molex connection is on bottom of hub.
