Aileron, rudder and elevator trim wires along with flap POS12 position sensor.
These little gold signal pins were tough. Used die E on molex crimper...worked well but wire was so short, flimsy. Hard to get a good feel. Ended up with about 1/8-3/16" stripped wire and that worked well.
Mistakenly put Elev. orange wire in pin 3 hole and s/h/b pin 1.... thought about re-tagging wires and pins. Ended up ripping Or wire out and FORCING pin back through connector. Redid OR pin.
Other tip learned for these little pins on 26 AWG wires.... push pin in a bit, but use needle nose pliers to pull pin through the rest the way. Otherwise, the little pin/wire wants to break if you push it in like the big 18/20 guage wires.
